configure log target xml-notification filter
configure log target xml-notification xml_target_name filter filter-name {severity [[severity] {only}]}
Description
Configures a Web server target with an EMS filter.
Syntax Description
xml_target_name Specifies the name of the xml notification target.
filter-name Specifies the name of the EMS filter.
severity Specifies the least severe level to send (if the keyword only is omitted).
Default
N/A.
Usage Guidelines
Use this command to configure a Web server target with an EMS filter. All EMS filters can be applied.
The following command configures the Web server target test2 with EMS filter filtertest2:
configure log target xml-notification test filter filtertest2
This command was first available in ExtremeXOS 12.4.
Platform Availability
